RCU Forums - View Single Post - Saito 72 setup low idle
Old 02-11-2008 | 03:56 AM
aussie jason
From: Gold CoastQueensland (Gold Coast Australia), AUSTRALIA
Default Saito 72 setup low idle
Can some one help me out with the set up on a Saito 72. I am swinging a 13 by 7 prop max rpm 8500 and at low idle only able to get it down to 4000 rpm before it cuts out. Have had many guy's at the club adjust the low end idle screw, and yes it does say not to adjust it so now I need to try and set it up to fact setting. A guy at the local hobbie shop said to screw both top end and low end neddles in and then adjust them equel distance two turns as a basic setting and try from there is this a good way to start? It may sound a little confusing oh and 10 % nitro also and side mounted.
Thanks hope you can help.
