RCU Forums - View Single Post - Sopwith Camel Stability
Old 02-11-2008 | 11:00 AM
TFF
Default RE: Sopwith Camel Stability
They don't fly all that bad, they just don't fly like a pattern plane. Rudders are small so there is a bit of tail wag and the under-camber wing makes too much lift when moving fast so it will climb. You just have to step up to the challenge. When you start changing the dimensions too much it starts loosing its bulldog charm.
