RCU Forums - View Single Post - Remote Control range failed
Old 02-11-2008 | 12:09 PM
Codeblack's Avatar
Codeblack
Default RE: Remote Control range failed
also did you do anything modifications to the snowmobile last time you ran it? no messing around with antenna placement? because once when i was very little i mounted antenna directly to an aluminum body (scratch built r/c) which was mounted to an electric motor.. the pulse from the motor distorted the signal and the range went poopy.
