RE: HFP10 programmer
Unfortunatley, the new HFP-20 uses a new board; it is not just a software update so the HFP-10 cannot be updated. You will however still be able to use the HFP-10 programmer with the new 79XX series servos but you will not be able to utilize the servo overload protection feature or reduce the resolution from High to STD if you want to program the servo travel for greater than 90 total degrees of travel.
So you are not being forced to upgrade your programmer with the new servos as the HFP-10 will still program them just like they were the 5XXX series with the exception of the extended EPA due to the default High Resolution setting. Not that if you do program the new 7XXX series servos beyond 90 degrees (45 deg. each direction) with the HFP-20 you will have to go back to the standard resolution.
I agree if would have been nice to be able to update the HFP-10, but unfortunatley it was maxed out with the processor it uses, so the HFP-20 had to be made in order to advance our servo technology.
Mike
