RCU Forums - View Single Post - Comp ARF Flash update
Old 02-12-2008 | 10:42 AM
  #647
digitech
My Feedback: (10)
Default RE: Comp ARF Flash update
ORIGINAL: acw
Also what alternatives are there for the landing gear, wheels and brakes other than what is offered my Comp. ARF?
Some are using Jet 1A. I believe that Russ is using Tam's gear and Rafael is using some BVM Bandit gears.
Jet 1A users have reported in this thread that it is required to modify the airframe for it to fit properly. I'm using the stock Behotec LG.
Arnaud
you dont need to alter anymore then with the original gear
the new oleo,s that came this year have almost 0 offset.
the "old"ones you needed to trim a bit of the thunnel
