RCU Forums - View Single Post - the hyper st PRO thread!
Old 02-12-2008 | 11:36 AM
  #705
supertib's Avatar
supertib
Default RE: the hyper st PRO thread!
ORIGINAL: kx_maduk
hi ,
i am almost 100% its not the angle of which my wheels can turn because i have set them up perfect . im using a futaba s3305 and s3050 on steering ( s3305 is in their know because of its torque ) and i have a hitec 665 i think and a futaba s3050 for throttle.
prehaps i should tear her all down and rebuild using stronger oils all round for shocks and diffs ? i really dont know .... maybe its just a simple mistake im making ? i really dont know .
Okay your using very very poor servos for your application...way too slow and not nearly enough torque, most definitely the reason why your Hyper is not steering well...........not trying to knock your gear, but your servos are not nearly good enough for Truggy steering, not even close
Futaba 3805
Speed: 0.25 sec/60° @ 4.8V 0.20 sec/60° @ 6V Torque: 124 oz-in (8.9 kg-cm) at 6V 99 oz-in (7.1 kg-cm) at 4.8V
Futaba 3050
Speed: .20 sec/60° @ 4.8V, .16 sec/60° @ 6V
Torque: 72 oz-in at 4.8V, 90 oz-in at 6V
Length: 1.57" (39.8mm)
Width: .79" (20mm)
Height: 1.50" (38.1mm)
Distance between center of mounting holes: .39" (9.9mm)
Weight: 1.7oz (49g)
