RCU Forums - View Single Post - Comp ARF Flash update
Old 02-12-2008 | 11:55 AM
  #652
digitech
My Feedback: (10)
Default RE: Comp ARF Flash update
ORIGINAL: Joe McBride
ORIGINAL: digitech
you dont need to alter anymore then with the original gear
the new oleo,s that came this year have almost 0 offset.
the "old"ones you needed to trim a bit of the thunnel
These fit without mods? Will they fit (or can they be modified) 8mm pins? Do they fit the stock (behotec) wheels and brakes?
What is the part #?
Joe
i believe the wheels and brakes are Intairco right?
if they are the brakes should fit (send me the inside measurements to check) and the axle we can set to (6.35mm-1/4 inch)
the oleo,s are from behotec
the ones you need are J125.1021
look under large oleo,s
anmd you need a couple of 8mm pins
so yes you need to "upgrade"the retracts.
