RCU Forums - View Single Post - Tail hunting problem
Old 02-12-2008 | 05:32 PM
gnd2
Default RE: Tail hunting problem
ORIGINAL: Hornet 1
Just need some quick help from the heli pros out there. I'm using the futaba 401 gyro. I never had this problem before I think its because I'm using a different radio with it and I cant figure out how to stop the tail from hunting around.[:@] The radio that I'm using now does not have a remote gyro sensitivity adjustmet option in the program menu. What am I doing wrong here.... The Revo mix is at 0% any help would be appreciated.
thanks, Luis
What you're doing wrong here is not telling us what radio you are using or how you have the radio and gyro setup, what servo.....
The only way to control the gain on that gyro is with the radio, so you have to plug the single wire into a receiver channel and set that channel up to control the gyro gain. If your radio doesn't have a "gyro" menu, you can usually use the ATV (aka "travel adjust" or "end point adjust" ) for the gyro gain channel.
Oh, and revo mix should always be 0 with HH gyro.
