RE: DX6i with CX2
Are you getting a 'link' light LED on the Rx?
Are the servos moving?
Make sure you reduce the throttle trim all the way to arm the system..... Maybe even increase the low throttle ATV if you need to....
A model memory created in AIRCRAFT type will work fine with the CX2.
Bind on the correct model.
David
