DX6i with CX2
Is there any1 using a dx6i with there cx2
I think i have a problem or have done something wrong i'm trying to setup a dx6i on my cx2
I have done the binding (put dx6 bind plug on battery connection on rx then connect power to heli the turn on power to tx holding forward the trainer switch till rx leds stop blinking) all done
But i have no throttle ???? Any1 know y ????
Ail and Ele had to be reversed they seem to b working ok
ORIGINAL: Krash68
Are you sure you have a DX6i and not a DX6? DX6i is DSM2 (like CX2) and the DX6 is DSM.
Reason I ask is because the DX6i isn't even available yet is the US except as packaged with the Blade400.
Are you getting a 'link' light LED on the Rx?
Are the servos moving?
Make sure you reduce the throttle trim all the way to arm the system..... Maybe even increase the low throttle ATV if you need to....
A model memory created in AIRCRAFT type will work fine with the CX2.
Bind on the correct model.
David
David
