RE: Byron Wedell Williams Racer Build
Finished up the Lt wing by drilling the servo hatch and attaching the servo mounting blocks. Then the aileron control horn was placed per plans. I'll do the rods for both ailerons later. Will do the final sanding later as well.
Building the Right wing half starts with setting the blocks on the plans as before but the ribs are placed on the rods UPSIDE DOWN from the Lt wing build. The spars are mounted.
Pete
