RCU Forums - View Single Post - Glue recommendations please?
Old 02-14-2008 | 08:49 AM
[AKA]StraferX's Avatar
[AKA]StraferX
Default RE: Glue recommendations please?
All the above information is very good. I like to use tite bond 2 as it has a good working time, makes good joints and helps me to not build to fast. Gives me time to make a plan before i move forward. One of the only glues I would not recommend is Gorilla Glue. It expands to much, is hard to work with and generally a blathering mess..strong as hades but definatly their are better choices. CA glues are good when you need it to stick right now and not move just watch the fumes, use well ventelated area. Good luck with your kit.
May your joints be tight and your blades forever sharp
