RE: $56 Skymaster!
Navav2002, I don't disagree with you.
It is a question of what is "good enough" vs overkill, and is a personal choice IMHO
The question is "what do you want out of the repair?" If it's just to get an airframe in the air with the least fuss, then CA is fine. If it is to make it back to the original as close as possible with the least weight gain, then you are absolutely correct.
