RCU Forums - View Single Post - DL-50 engine
Thread: DL-50 engine
Old 02-15-2008 | 07:57 AM
  #1325
wavy777
Default RE: DL-50 engine
ORIGINAL: craigteffe
Wavy777- Is that a tuned pipe or a canister system? Which brand is it and did you have to cut the header length to tune it to tour engine?
Craig - its a tuned pipe system from KS, i bought it from Germany, but i guess you can get it easily over there too. The header and pipe were the ideal length for my rpm's (730mm for 7000 rpm), no cutting was involved. You can even order the header for your airframe, if its available as i did for my EF yak. Highly recommended!
Look under 'sets' on this website to see if your aircraft is there (mine was no.551), i also bought the mount system too, which worked a treat.
http://www.krumscheid-metallwaren.de...op.php?lang=EN
