RCU Forums - View Single Post - omp edge ve build
Old 02-15-2008 | 11:13 AM
evanspa
Default RE: omp edge ve build
glue on a piece of balsa the size of the root rib over the root and then sand it carefully
That's exactly what I did. Worked out perfectly. I'm good to go!
The only other Q's I have is about mounting Radio/Batts.
What is the best method? Batts in the center of Fuse, Rx in the left wing? The sheeting on the wing seems soft(not covered yet)
