RCU Forums - View Single Post - Help! need 3W Fun Extra AUW? please.
Old 04-22-2003 | 12:57 PM
rcman84341
Default Help! need 3W Fun Extra AUW? please.
I have one and have flown it
I don't know the full weight but I will put it on a scale and let you know
As for the plane, it flies very well no bad tip stalls easy to land
I bought the whole combo package with the 3w 24 motor
The motor has a lot of power and works very well with the plane
The only problem with the plane is that it is build very light not very strong
On the first flight, I landed what I thought was very light and the landing gear pulled off
I went home and fixed the landing gear and flew it again
I got three flight on it, landed and come in to fill it up and saw that the fuse side just be low the wing had a split in it
I think that this happend when I did some snap rolls
So with that said I would reinforce the landing gear mount and lay in some balsa up that sides of the fuse, next to the wing and you would be in great shape
Thats all I have done so far and I have about 20 flights on it now the motor is starting to come alive and I haven't had any other problems
I hope that helps
David
