I think at the moment its a 54 tooth. Not sure which way to go...I also put some nice big tires on it. Took of the anacondas and put on another set the guy sent with it, they're sporttraxx talons...dont know if those are any better or not, but they're a lot bigger then the stock tires..
Anyways...SO a arms should be aluminum? You recommend aluminum shock towers as well?
ORIGINAL: angus67
get rpm arms now, dont get stuck somewhere with busted arms! also to keep the front down, lower the front, or use taller spur gear.
