RCU Forums - View Single Post - cx2 servo horns
Old 02-17-2008 | 04:09 PM
Coyote64's Avatar
Coyote64
Default RE: cx2 servo horns
Moving the servo hole out increases movement of the servo and is mainly used for flying outside
It increases the movement of the rotor, which yes does give more manovarbility but also brings the rotors closer together ie blade clacking
No real benifits flying indoors
If you do this mod you need to open the second hole a little as its too small, and i would advise the extended inner shaft mod and shortened and lightened flybar mod to get the best from the heli
