E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
cx2 servo horns
Old 02-17-2008 | 03:56 PM
hollywood54's Avatar
Default cx2 servo horns
Hey Guys,Has anyone moved the push rods out to another hole in the servo arm?If so does it give it faster ff? My cx2 is in the first hole closest to the horn screw.It is very slow in forward flight.Just wondering Thanks
Old 02-17-2008 | 04:09 PM
Coyote64's Avatar
Default RE: cx2 servo horns
Moving the servo hole out increases movement of the servo and is mainly used for flying outside
It increases the movement of the rotor, which yes does give more manovarbility but also brings the rotors closer together ie blade clacking
No real benifits flying indoors
If you do this mod you need to open the second hole a little as its too small, and i would advise the extended inner shaft mod and shortened and lightened flybar mod to get the best from the heli
