Fuel System on Conversion
I use all three openings in the tank plug;
1) clunked w/ filter direct to intake of carb;
2) clunked w/ filter return line from primer bulb, Redundant yes but I plan to use that line as a fill for tank as well and fuel can not be too clean;
3) vent line to aft exterior of fuse, to help keep things cleaner; it will exit far enough to allow a plug for fumes while transporting, I do not like the smell and I still smoke in the car.
Tygon lines with hose clips inside fuse.
