RCU Forums - View Single Post - vortex cx2 motors????
Old 02-18-2008 | 05:10 PM
evdreamer
Default RE: vortex cx2 motors????
ORIGINAL: crawlerking11
where can i get teh xtremes ive had bad luck with the stock motors also will the heat sink work on the xtreme motors and how much do they cost moneys really tight i rolled my truck 2 days ago
I and others like UShobbysupply. I use the heat sink on the motors with no problem. They are $16 a piece. You need the A and B motors. When you install them make sure the capacitors are on the outside. With carbon brushes they should last longer than the stock ones. Then you can just change out the brushes which I think are $3. http://www.ushobbysupply.com/product...roducts_id=248
