Tools to remove feathering shaft?
I just ordered two 5mm nut drivers to remove the locknuts that hold the blade grips and feathering shaft. I hope these
drivers will fit between the arms of the blade grips. I'm sure anyone who has removed these locknuts knows how tight the space is to work in. None of my very small sockets will fit in the space. Any suggestions on removing the nuts would be appreciated . Do extra long needle nose pliers work? I was thinking about custom grinding down a pair while waiting on the nut drivers---- those are 5mm nuts, right?
Don
