RCU Forums - View Single Post - vortex cx2 motors????
Old 02-19-2008 | 02:18 PM
eat2muchrice's Avatar
eat2muchrice
Default RE: vortex cx2 motors????
ORIGINAL: H3li
No-one has asked the question - How old is your CX2? You say you have owned it for about a week?
If so, your Motors shouldn't be defective after just this short time!
Have you checked all the usual places for Binding, that could be causing loss of power?
I recently experienced reduced flight times, and blamed either the Motors or Batteries!
Turned out the Outer Shaft was bent, causing binding also on the inner shaft, and draining the battery in no time!
Worth the inspection, and could save you some $$ !
Anyhow, I'd recommend the Xtreme 180 motors if you do decide to "upgrade".
Cheers.
yes, its not your motors. Last thing you should check would be them.
1. Check Blades.
2. Check shafts.
3. Gearmesh.
4. bearings.
5. Then motors.
6. Test 3-1.
All the how to info is in here.
Tips/Repair/Guides/Mods Links
http://www.rcuniverse.com/forum/m_70...tm.htm#7035042
