RCU Forums - View Single Post - Pull pull, Solder or crimp?
Old 02-19-2008 | 09:20 PM
Edwin
Default RE: Pull pull, Solder or crimp?
I crimp. I dont like to solder cause the vibrations MAY eventually break it. Sorta like electical wire, which I have seen break. Probably being paranoid but crimping has worked for years for me so I see no reason to change. I use 80lb plastic coated fishing leader wire, dimple crimp (same as pilgrim) then heat shrink over the crimp.
Edwin
