RE: Poll the mob? New plane question.
After having the following planes: Show time .90, EF 68" Yak, U Can Do .46, 3 .60 U can Do, X100, Velox 68", Fusion .90 ARF, the best 2 are : #1 Fusion, #2 Velox. If you cannot stand a "plank" for a fuse, than get the Velox while they last. If you can figure out how to get the Velox under 9 lbs, it would be even better.( CF gear, mousse can muffler, lighter battery & servos, CF push rods). The Fusion does the most with minimal setup, the Velox might require more setup tweeking. The Velox does beautiful KE & rolling harriers, a little hard to hover. The Fusion hovers so easy , slow HA KE the best, I mean S L O W W, it just hangs there in any kind of head wind. Even though the Fusion is way lighter, it doesnt seem to get knocked out of hovers like other full fuse planes do. I'm keeping my Do & Velox, but when they "expire", it will be the Fusion & 50cc planes for me, the Double Vision & TOC Yak, its true, bigger heavier planes do fly better.
