RC freak there are many out there to choose from, I saw your other post and it seems you are a newby, so you want a good trainer type plane to start with
In the RTF there is the Super cub this is a very good trainer but is a bit large so if room is an issue maybe not the best choice
Then you have the Mutiplex Mini Mag again a excellent trainer plane and it's EPP so it's very tough
Mutiplex also has the easy star, this is a pusher type plane so it gives you a chance to learn without the motor up front to damage, it is more of a glider so it can fly nice and slow
Exceed RC has a plane called Wild Hawk that is a copy of the easy star, again a pusher and glyder type plane, it too is EPP foam so it's tough
It realy is going to boil down to what kind of plane you want and then find one that fits your needs from there
The advantage to all these planes is they come RTF for under 200.00 and they can easily be upgraded to brushless later and become a whole new plane , and being EPP they can handle quite a beating
Good Luck with whatever you choose
