RCU Forums - View Single Post - What is gained by adding more expensive Nitro to gasoline ?
Old 02-21-2008 | 11:44 AM
av8tor1977's Avatar
av8tor1977
Default RE: What is gained by adding more expensive Nitro to gasoline ?
That would have WAY too much oil. Buy the 10/10 fuel, or buy a gallon of methanol to add to your glow fuel, then mix it as normal with the high test gas. It will be a little light on nitro done that way, but should work ok.
AV8TOR
