RE: Please help, a new problem recently.
the battery should reach a max charge of 12.4v, if you can check that with a volt or multi meter.
the best upgrade after the motor/esc is the 43t tail upgrade, gives you more tail authority and prevents the belt slipping off the roller guide. After that I'd say a hh gyro.
