RE: Alpha 60 CG HELP!!!! I need 4oz in tail.
Have you thought about using a wood prop and a prop nut instead of a spinner? You may already have a wood prop I don't know. This may not get all the weight off the nose you need but it will help.
Also what kind of motor mount does that plane use? i have seen a few ARFs with heavy alum mounts. A glass mount would only be a few bucks and be lighter.
David
