RCU Forums - View Single Post - Cheap ARF Ideas.
Old 04-21-2003 | 05:58 PM
tiggerinmk
Default Cheap ARF Ideas.
If you're thinking "really cheap" then I guess you're going to put an existing engine in it rather than buy one. In your 1st post you mentioned both 40 & 60 sized planes.... Do you have both engines?
I'm not sure about the Avistar, I've heard that the tail falls off on a hard landing....
A 60 sized equivalent (and a lot stronger) would be the Hobbistar 60 MkIII but its a tad over $100......
The Superstar 60 is getting cheaper every day and was around $97 when I last looked but its a flat bottomed trainer..
The Brightstar might also be worth looking into. They are around $93 right now... (40 size low wing trainer, flat bottom wing)
