RE: Need Help Modifying Kaos Please
Thanks. If you have a picture that would be great!! The only thing is that by having the throttle arm on the right side of the engine it sits behind the cyclinder. I would think that it would be hard to get the rod bent enough to go back to the arm. Unless I'm not understanding which is most likely the case. If you had a picture I think that woulod help me a bunch.
Thanks again.
Gene
