Hi According to Bax at Futaba it is 3 volts nominal...........just go to the Futaba factory support section and you can see what he sent me
I have seen that. However, he also says that it can drop to 2.65 volts depending on the channel and servo used.
What I want to know from Hitec is if this is OK????? Can I use Hitec servos or do I need to buy Futaba??? If they work on the bench, does that mean that they will work in the air???? I don't want to lose an airplane over this.
DK
