5955TG questions
My Feedback: (16)
CA
5955TG questions
Hi, my question is what would the effects be on running these servos with a output pulse voltage lower than 3 volts?
The reason I ask is I just found out that the new Futaba R6014fh 2.4 recevier may be putting out only about 2.76 volts on the output impulse signal side of the recevier.
I heard this rumor AFTER I bought the radio. There are no spec values with the enclosed paper work of the system. I have about 15 5955's and I sure don't want to buy another bunch of Futuba servos just to make this system work. I may need to send it back for a refund.
Steve
Steve
CA
RE: 5955TG questions
Below the 3 volt minimum our servos (and most other servos) require the servo could:
A) not work at all
B) work erratically
C) work as normal. With this option a ANALOG servo may still work ok as it is less tolerant than a digital servo.
Options A and B are most likely.
A) not work at all
B) work erratically
My Feedback: (16)
CA
ORIGINAL: Brendan Lugo
A) not work at all
B) work erratically
A) not work at all
B) work erratically
This Futaba seems nice but after dealing with their customer service department I think I'll send the thing back and just wait till HiTech comes out with their equipment. This had taught me a lesson about customer service and that is it should be #1 when it comes to repeat customers. After all most of the radios out there are not that much different form one another so it is the service that a company provides after the sale that is most important.
HiTech seems to understand this concept better than most
Again Thank You HiTec
VA
I have a 6014 reciever, and Futaba reports that it is nominal 3 volts for the signal and may vary from 2.65 volts to 3 volts depending on the channel and servo used.
I have multiple 5955 (and many other Hitec) servos. I tried one of the 5955's on the bench on multiple channels, and it seemed to work fine. Does that mean that it will be OK to fly with it?? This is a huge issue for me because I have several large planes, and basically use Hitec servos in all of them.
DK
DK
My Feedback: (16)
CA
ORIGINAL: DKflyer
DK
DK
VA
Well, up above it says that they may not work on less than 3 volts for the signal leads. I need to know if this is 3 volts "nominal", or a minimum of 3 volts at all times. As I said, they are working fine on the bench. Just don't want any surprises in the air because the signal voltage drops to 2.65v.
DK
DK
My Feedback: (16)
CA
ORIGINAL: DKflyer
DK
DK
VA
Hi According to Bax at Futaba it is 3 volts nominal...........just go to the Futaba factory support section and you can see what he sent me
What I want to know from Hitec is if this is OK????? Can I use Hitec servos or do I need to buy Futaba??? If they work on the bench, does that mean that they will work in the air???? I don't want to lose an airplane over this.
DK
My Feedback: (16)
CA
ORIGINAL: DKflyer
I have seen that. However, he also says that it can drop to 2.65 volts depending on the channel and servo used.
DK
DK
CA
If it works on the bench and there are no problems, it will be fine in the air. The signal line voltage isn't going to change much as the flight load the servo sees does not effect the signal line voltage.
3 volts is more our minimum voltage as 3.3 volts would be our nominal.
You guys are scaring the s***** out of me.. I just ordered a 12FGA with teh 6014 receiver... and my Edge 540 is full of 5955's...
I'm not currently using a power box on the plane (using JR 2.4 radio), and wasn't planning on using a power box with the Futaba setup.... If I do go with the box, would it eliminate these concerns?
My Feedback: (16)
CA
ORIGINAL: reyn3545
As far as a PowerBox correcting this issue??? I would have to say no. I use a PowerBox 40/16 Evolution just because I can use two LiPo's to power those big servos. And because if a servo burn's up for what ever reason it won't knock out your receiver. You see a PowerBox regulates the volyage to 5.9v to the servos and works the two battries to get that constant voltage. It also has other benefits as well.If you want to read more go to the Duralite battries web-page and you can read the owners manuel which also shows the benefits.
Another thing about the PowerBox is that you can run up to 20 servos at one time off it that is on the 40/16 Evo model. All getting the same 5.9 vo;ts. There are other makers of these types of devices like SmartFly and I'm sure others but PowerBox and SmartFly are two I know of.
The PowerBox does not change the signal voltage.it just makes sure the voltage that comes in one side is going out the other side at a even and constant rate.
My Feedback: (23)
Hello friend,[8D] you are not correct,
please look into all manuals of the original PowerBoxes, not coppies as the smartflys,
all original PowerBoxes have puls amplifiers inside for each channel and the signal voltage is always constant 5,0 volt,
if the Futaba 6014 have only 2,7 volts on the signal, then helps also the original PowerBox, the signal is 5,0 volts output and all electronic parts, servos, electronic valves, ECU will work on a PowerBox!
If you have problems with the servos on the Futaba 6014 then take a PowerBox and all works fine.
My Feedback: (16)
CA
George, here is a copy of the letter from owerBox I got. It says the basic same thing as you have said
Hello Steve,
Yes, I can confirm, that this receiver 6014 will work with the most of our PowerBoxes. The newest, from the last 3 years, can handle the voltage up from 2,5 volts. The PowerBoxes with RRS inside or the RRS module can all pulse handle up from 1,0 volts, so in your case, the PowerBox Royal and 2 of this receivers are a very perfect setup. In big planes with long servos leads, if there are HiTec servos in the plane, or other electronic items what need 3,0 volts input, is the PB Royal absolutely necessary, because when you connect this electronic items on the PowerBox, then they get a pulse voltage of minimum 4.5 - 5,0 volts, so they will work all very fine.
If it is an older PowerBox and doesn´t function on the 6014, then we update it, also not a problem.
When the Box work on the receiver then it is o.k., we have made some tests with all PowerBoxes, special with a heat over 50 degrees, because some of our customers ask us, what happens over 50 degrees, and we can say, that it is the same when the Box work by 20 degrees, then it also work by 50 degrees, for example, when it was by 20° 2,62 Volts, then it was by 50 ° not much more, mostly 2,63 or 2,64 volts. We think that the electronic parts what we give in our boxes they are all designed for 150 degrees ( MIL specification), and we have all our PowerBox with gold plates, so it does nothing when the temperature is a little higher.
We can say when the Box will work then it is the newer version, not older then 3 years, and it will work with this receiver.
Thank you for your interest, if you has any question ask me please.
kind regards / mit freundlichen Grüßen
Emmerich Deutsch
PowerBox Systems GmbH
Ludwig-Auer-Strasse 5
ORIGINAL: DelGatoGrande
Steve
