RE: Reciever Question
When you crash a reciever, the two things that are most apt ot go wrong is a cracked crystal. Note: there are two crystals in most receivers, the one that you can change and one that is soldered into the PC board and not readily replacable. Both are quite fragile and easily damaged if given a hard shock or bump. If you receiver acts up under vibration, chances are that one or both of these crystals are fractured.
