why....
Anyways i finially decided to try and make my nemesis run again but with little luck. When i first started it, it ran wheel. Then it quickly reached temps of over 260 with stock settings at HSN 3.5 and low 1.5 in from flush. So i turned it off and decided maybe i will richen it a little. Well after that the glow plug died. So i put a new plug in and started it up again. But a few seconds after i pulled the igniator off the truck died... So i have a truck that is running through plugs and gets hot quick. Any help would be good. Also engine has less then 1 gallon...
