RCU Forums - View Single Post - Reciever Question
Old 02-24-2008 | 10:47 AM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Reciever Question
ORIGINAL: F-15 Fan
It doesn't work at all, the guy at my LHS said that 9 out of 10 times its the crystal, we will find out when I do the range test with the new crystal.
F-15,
I'm not trying to argue or discredit your LHS, but this isn't true. While it is true that a lot of times it is the crystal in a receiver that causes problems. But it is nowhere near 9 out of 10 times. There are a lot more problems that can and do occur in a receiver after a crash that happens. Cracked circuit boards, damaged electronic components, cracked solder joints, and many other problems can pop up. A range check is not a accurate test of the operation of a receiver that has been involved with a crash. As has been stated earlier in this thread, the only real way to know if your receiver is 100% operable is to send it in and have it serviced by a reputable repair facility. Many times problems with damaged receivers won't show up in a range check, but will show up when subjected to the rigors of flight.
Ken
