ORIGINAL: Jeff Boyd 2
ORIGINAL: CHV69
I had to add lead to the firewall of mine to make it balance where I feel comfortable.
OS 1.40 Hyde mount Mueller header and Aeroslave pipe. Stab mounted Servos
185 mm back from the leading edge.
Carl
Great . . I hope mine is like yours. I am going to fit my well sorted OS160FX set up and as it's heavier, I was fearing the worst.
Sounds like there is BIG variation in the build up of these things
JB
Jeff,
If you are going to use the OS160FX, try to keep the front section as light as you can, I had to move the receiver battery pack as far back as I can reach to get the CG in ball park, but still has to add some weight in the tail later.
Kevin
