RCU Forums - View Single Post - Paint for Pattern Planes
Old 02-24-2008 | 07:01 PM
  #35
fox59
Default RE: Paint for Pattern Planes
ORIGINAL: RCDENT
In the late 1980's, I remember seeing one of Steve Helms's Auroras up close and inside. The finish was immaculate and the fuse appeared to be made from a molded balsa shell. All of the inside parts were sanded smooth and coated so that the interior of the fuse was just as impressive as the outer finish. At the time, I think he said they cost around $2,300 to 2,800 each. Very professional!
I've been pricing out various paint systems, and now I see why film coverings and ARF's are so popular! I can buy the ARF Intruder for little more than it will cost me to paint the Tipo with some systems! Ed has a good point about planes accumulating hangar rash, etc. Still, we do this hobby/sport for a number of different reasons. Sometimes, the important thing is just to have something that flys, other times, there is a lot of satisfaction in the craftsmanship and individuality that goes into a good painted finish. I love to eat out. Sometimes I feel like fine dinining and wine, sometimes I feel like babecue and beer. Both are great, but different. One thing I don't like about film finishes is that the balsa surface is still soft. I almost feel like the plane gets dented every time I pick it up, unless I'm extremely careful. Also, the edges always start peeling up after a while. The auto enamel and epoxies make beautiful finishes, but seem difficult to touch up when dinged. Old fashion silk/dope was so easy to fix.
I think the bottom line is, results depend on the builder and his/her talent and experience with the materials being used.
Anyone used the Nelson Hobbies system? Sounds good, with water thinning and clean up. www.nelsonhobby.com
I am currently using the System 3 paints on a senior Falcon. So far, I am very favorably impressed. The stuff is water thinning and cleaning, can be brushed, can be used on open fabric - in my case Koverall - and has very little odor, and , when applied in thin layers, will dry enough to sand or recoat in 15 minutes or thereabouts. If you need to really hurry things along, you can heat the painted surface up, or bake the part at low heat in an oven and thick layers will dry in a few minutes. Since it air dries, the thicker the layer the longer the dry time. I am getting the hang of sprayng - its a bit different as the "volatiles' are not like solvent-based paints. All I need to do is dial in the paint and air settings, use as little "thinner" as your gun will allow ( I am using a devilbliss touch-up gun at 50 psi) and seems like the more pattern air the better as it speeds the evaporation. As is common with spraying, keep the temp above 60 F. First went too thin/wet, then too dry. Should nail it on the next shoot this evening.
NN
