Originally posted by Pilottx
I've never really had a problem with the elevator, occasional tightening of the closed loop, nothing else really.
What are you experiencing??
My reason for doing the rudder was because in a hover the Hype would always drop to the left even with loads of right thrust on the motor. Fitting the servo in the tail cured the problem, much faster and much more powerfull rudder action.
This is more of precautionary thought that real need.
I have the feeling that elevator is putting much more
loads that rudder.
What servos are You using on rudder/elevator ?
