RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 02-25-2008 | 02:51 PM
  #616
RoysterDW's Avatar
RoysterDW
Default RE: Venus II
ORIGINAL: nonstoprc
Two fuel tubing lines routed outside the fuze: one for fuel and one for vent return. The beauty of this approch is that when I am fuelnig, all fuel goes to the tank. There is no risk to flood the carb. See pic 2. The jack before the 4 tube connectors is for the glow plug ignitor t be remotely connected. I found it is hard to locate the glow plug when YS is inverted.
I used a CF tube with 4-40 threaded rods JB welded at boh ends to build a push-rod for rudder. Saved some weight. see Pic 1.
How do you stop the fuel line from popping off during flight?
