RCU Forums - View Single Post - Deezil question
Old 02-25-2008 | 03:35 PM
Tee Bee
Default RE: Deezil question
"The Deezil prop driver "is" a flat washer with a "D" shaped hole."
Cool! It looks like I've got the original prop driver, then. This engine is getting more interesting all the time. I sure appreciate the info you all have shared. Here's a few shots of it disassembled. The needle valve removes from the brass collet very easily. I'm supposing that the knurled section is supposed to be holding it in there tightly. The backplate gasket looks to be in good shape. The piston/cylinder fit is pretty nice as well. I just need to get the contra piston unstuck.
ID:	888449   Click image for larger version
ID:	888450   Click image for larger version
