RCU Forums - View Single Post - Deezil question
Old 02-25-2008 | 08:54 PM
Tee Bee
Default RE: Deezil question
I can run it down with the compression screw until it hits the piston but the piston won't force it back up. You have to remove the cylinder and knock it back up with the dowel to readjust it. Other than that, the compression seems very good with everything oiled up. Now, I'll have to find some adequate diesel or figure out how to mix a small batch. The curiousity about whether it will run is increasing.
