heli spin counterclockwise in hover
I'm not familiar with that gyro, but how are you switching between normal mode and HH, are you using the radio,( gear channel)? If so, when you switch to HH, the servo should not drift, if it does, you need to use the rudder trim to make it stay still, then reset your linkages in normal mode to hold the tail straight.....Coop
