RCU Forums - View Single Post - CMP 540 Edge T 28% Build
Old 02-27-2008 | 11:24 PM
opjose's Avatar
opjose
Default RE: CMP 540 Edge T 28% Build
Thanks I've read this too. I've had RF interference problems with glow engines as well when I once used a metal rod and clevis set.
I'm actually sticking the receiver towards the rear of the canopy area so it will be quite far from the engine.
I have a resistor plug in place and I may also add an aluminum shield to the EI system to play it safe.
Thanks for the heads up.
