Tail wagging at a hover......
I accidently deleted all my heli settings in my DX7 when programing my new fixed wing nitro and now with the same setting the tail is wagging real bad, I noticed the main tail rotor drive gear(the one attached to the main gear) is warped a bit more then usual, so my question is do you thing the the warped gear could be causing rpm fluxuations enough to cause tail wagging? thanks in advance!
