RCU Forums - View Single Post - Hitec High dollar problem round #2
Old 04-23-2003 | 01:58 PM
DSA.308's Avatar
DSA.308
Default Hitec High dollar problem round #2
I had started with one 5735 and 2 5945. I have but one 5945 that hasnt crapped out. Of the 3 servos I have 2 of the 3 have failed.
I have a JR-R1 Radio and am very capapable of setting end-point adjustment , servo throw, ETC. The Failure isnt because of my in-ability to set my radio up correctly. I am using it in a 1/5th scale car.
If you guys have 100+ 5945 without a single failure- get ready for #1, think if this had been in a 40% plane fellas.
By the way the 1/5th scale that I was using this 5945 in was used for less than a half gallon of gas, since the servo was brand new. Also, it was only being used as a front disk brake supplement, and was only actuated upon brake application, which happens rarely in a 1/5th scale, do to the excellent engine brake of the 23CC 2 cycle engine. So my only point is that it was being used in a VERY mild application, far from keeping a wing surface in place for extended amounts of time such as in a 40% plane application.
