RCU Forums - View Single Post - Hitec High dollar problem round #2
Old 04-23-2003 | 02:18 PM
DSA.308's Avatar
DSA.308
Default Hitec High dollar problem round #2
is that address to the warranty dept.?
The servo that failed is the one on the right, in this picture. It was set up on channel 3 (front disk brake) which was mixxed with channel 2 (throttle/rear disk brake). at 88% of ch. 2's 100% full range. Sub trims are all at 0. ch 1 is set at the middle on the main trim, the steering is at 4 clicks to the right. Travel adjust on the steering is:L=85% R=78% throttle F=73% B92%. Channels 1&2 are reversed, and channel 3 (aux) is in the normal position. I am using the SPCM modulation.
Anyone see any red flags as to possible problems with my setup?
