RCU Forums - View Single Post - Balsa Weights
Old 03-01-2008 | 06:05 AM
BMatthews's Avatar
BMatthews
Default RE: Balsa Weights
ORIGINAL: fritzke
Grams? Maybe you Canadians can think in grams, but south of the 38th it's still yards, pints and slugs.
A gram is something you dunk in milk, or make a pie crust out of!
Dave
Oh... I still think in terms of pints. I actually think a lot more clearly with a pint in my hand.... well it seems more clear to me at least.....
If you share the spreadsheet file out I could probably multiply all the columns by the grams factor or set up a set of shadow columns (not a big spreadsheet brain so I'm not sure if that's the right term) over to the right hand side that uses the oz columns and just multiplies the numbers by the conversion. Then we'd have both.
