ORIGINAL: calvinlo
Hmmm...by diagonals of channels 3 and 4, are you saying the same thing as the answer given by Elmod FAQ section below?
Question: The tank keeps not moving after installation of the Blaster. The turret works fine!
Answer: If a Blaster is installed, the engine has to be "ignited". Move the left stick to the uper left corner for HL-electronics (down-left for proportional) to turn the engine on and off.
If that's what you mean, I've already tried pushing the left (or right) stick down left...but the tank does not respond. [&o]
Yes, but if your servo direction is wrong the lights should go on/off instead.
And if you got El-Mod PropCH6, nothing would happend when you go for "down left corner"
From Thomas at ElMod:
Case 1: Booster/TLS C6 Prop and Blaster II -> 8 channels:
Channel 1 - Booster acceleration
Channel 2 - Booster steering
Channel 3 - TLS C4 turret rotation
Channel 4 - TLS C4 gun elevation
Channel 5 - TLS C4 shot (low: MG, high: gun)
Channel 6 - TLS C4 further functions (high: engine on/off, full low: front light on/off, half low: optional light on/off)
Channel 7 - Blaster user sounds 1+2
Channel 8 - Blaster user sounds 3+4
Case 2: Booster/TLS, Prop Wire Set and Blaster II -> 6 channels:
Channel 4 - TLS C4 gun elevation (half way up and down), shot (full up: gun, full down: MG)
Channel 3+4 diagonals: up+left -> engine on/off, down+left->front light on/off, down+right->optional light on/off
Channel 5 - Blaster user sounds 1+2
Channel 6 - Blaster user sounds 3+4
Regards
Jake
