ORIGINAL: extra 300
Julio,
Thanks again for details, although i have flown with similar configuration in the past, i would be willing to try something new but how will i know that i have done setup correctly?
One more question regarding ailevons throws. I seem to have limited movement/deflection. Can you please advise yours?
Thanks. Regards.
Dany
Dany it sound like you have inserted your elevons to far into the wing which has limited your throws, i had to trim off the trailing edge of the wing to get the correct movement, i also modified the root section of the elevon by moving it back by 1/4 inch at the section that overhangs the wing. this allowed for full travel without bottoming out on the fuse.
Alan
